bblades and throotle up question >
Old 05-10-2009 | 11:04 PM
Default bblades and throotle up question
18ft. hews flatboat with 02 250 efi i'm running a bravo 1 24 pitch running 73mph at 5900rpm .pretty flat water .
Is there a prop that will performan better than b1 .
will 3 chopper be better or cleaver liting et.
obvouisly more top end..
I was thinKing 25 p chopper or 26 chopper three blade..
MOTION35 is offline
Old 05-12-2009 | 09:31 AM
bbladesprops's Avatar
Offshoreonly Advertiser
Smile
The Chopper 2 will probably give you a couple more on the top end but will suffer with load carrying.
Try the Pro ET 4blade.
I have one for testing if you are interested.
Brett
[email protected]
bbladesprops is offline
Old 05-12-2009 | 07:02 PM
The pro et 4 blade what would be the diffrence.
The cost of this prop.
MOTION35 is offline
Old 05-20-2009 | 10:50 AM
Smile
Then difference between the chopper would be more load carrying ability and similar speeds. Slightly less or slightly more.
[email protected]
