cant get it dialed in
my 32 active thunder twin 500hps about 575 ea spin my 30b1s into revlimiter at 86 on gps they are labbed pretty thin, tried a set of 32 labbed with the ring cut off had problems with blow out but once up only 4900 at 82 on gps put on a set of stock 30b1s 5300 at 83 on gps but made the boat porpoise. what do i need my 30s worked a bit or what.
Thanks |
Originally Posted by rssteiny
(Post 2888667)
Thanks Yep,,,just trhow a little more cup in and they should be fine ..... B BLADES !!!!!!!!!!!!!!!!!!!! would be the answer ! |
I think you need to loan me some horse power.
Brett at BBlades is helping me maybe he can help you too. |
Seems to me that your labbed 30's are close. If you want want to cut 50-100 RPM, Brett can do that easy but you might give up 1 MPH. What is your concern with the preformance with these props?
| All times are GMT -5. The time now is 10:36 PM. |
