#6 prop help >
#6 prop help
#6 prop help
Old 08-11-2009 | 09:06 PM
OkieTunnel's Avatar
Default #6 prop help
I have been advised to try some 5 blades to decrease transom lift on my boat. A buddy loaned me some 5 blades off another boat (he is a wholesaler) but not sure the exact size. I need about 16.5 by 33. The numbers on these props are: 10-33-05 C 18 Deg. 11426 I assume they are 33's with 18 degrees of rake but cant tell the diameter by the numbers. I will run them and that will tell me if 5 blades are going to settle the transom down but if they do I want to have a starting point to know what the next prop size to try will be. Thanks.
OkieTunnel is offline
Old 08-12-2009 | 08:01 AM
WildWarrior's Avatar
The more blades the more transom lift ,the blades will continue to try and find the surface thus lifting transom.The same goes for larger diameter props the more diameter the faster the prop seeks the top of the water as well.
For our set up and x once running mid to high 140s 5 blades have always goten squirly lifting transom without the addition of a 1/2" spacer. Then the trade off is a boat that is dragging a ton of water and never reaching full rpm!
Good luck!
WildWarrior is offline
Old 08-12-2009 | 08:44 AM
Brad Zastrow's Avatar
I ran 16.5 x 35 five blades on a 35 Motion with sixes with great success. They are much smoother without that vibration the four blades have. I ran that boat 155 mph.
Brad Zastrow is offline
Old 08-12-2009 | 10:24 AM
Elite Marine's Avatar
Always adding 10 MPH to your numbers...
Elite Marine is offline
Old 08-12-2009 | 10:34 AM
In which direction are you turning the props? This can have an effect on transom lift.
Due
Dueclaws is offline
Old 08-12-2009 | 11:07 AM
That was on Grass Lake in about one mile from the no wake zone. GPS with recall!! Four people in the boat. Props turning in. Cats guys have no need to lie.... That boat was crazy fast.
Old 08-12-2009 | 12:38 PM
We also turn our props in, and out of multiple props tested our particular set up hands down handles high speeds best with a
3 1/4" X dimension and at least a 17" diameter 4 blade prop.
Taking out diameter helps with stern lift as well!
Brett at BBlades is sharp as hell and can more than likely nail down your set up the first time!
Old 08-12-2009 | 12:55 PM
Not crazy fast, but turn my props in also.
Dueclaws is offline
Old 08-12-2009 | 08:37 PM
OkieTunnel's Avatar
Due
Props are turning in. Out would make it worse! X is at 3 inches which is ok to a smidge low on Motions. Motors are a little too far forward which is the real problem. Measured the diameter of my loaners tonight...16.5. They should be exactly what I am looking for as a starting point. Thanks all. I will let u know how much of a difference it made after the weekend.
Old 08-13-2009 | 12:51 AM
Coolerman's Avatar
PF Marine
5 blade props give more transom lift than 4 blades, but you can get 5 blades with higher rakes which give more BOW lift. I think merc has some 21* rake props now. Give brett at BBlades a call, he knows his stuff.
Last edited by Coolerman; 08-13-2009 at 08:21 PM. Reason: woops, was tired and scrambled info
Coolerman is offline
