what can be done with the P5X >
Old 10-22-2009 | 07:47 PM
crayolacrazy's Avatar
Default what can be done with the P5X
Has any one labbed these ,an what gains Im looking to pick up 2 to 3 mph Im running 30s and 31 s same speed 200r,s different
crayolacrazy is offline
Old 10-24-2009 | 07:55 AM
Hydros are usually pretty good right out of the box. Hydromotive does have what they refer to as a recreational lab job which I believe is only sharpen the leading edge and slight thinning. Hear it's worth a couple most of the time. I have a pair of 31 Hydro P5 Plus, the 16" ones, that were done by Throttle Up. They have had the diameter cut down and a ton of work done to them to reshape the blades to a Hering profile. They accelerate like crazy and work pretty well on my boat, but due to the high X are a little slow to get on plane, was told a little longer hub would cure that, just have not gone there yet. Might consider selling them, or work something vs those Herings you have.
P.S. So you understand me here .... I do realize the Herings are worth more.
RaggedEdge is offline
Old 10-24-2009 | 05:38 PM
CB-BLR's Avatar
Chris
When thinning and sharpening the P5-x's (which I have done at Herring), I can usually run one pitch steeper at the same rpm... ie.. i pick up about 150-200 rpm.
This makes the bigger prop faster at any given rpm.
Chris
CB-BLR is offline
Old 10-24-2009 | 06:50 PM
p5,s dont work on my boat
Old 10-24-2009 | 07:02 PM
Chris
Im looking to have my 31,s labbed Julie wont work on props the last time I talked to her ,in the spring 96.6 - 5800 r,s with 30,s------96.9 with 31,s 5600 slower getting on plain
Old 10-25-2009 | 01:55 AM
Contact BBlades and send the props to him.
Griff is offline
Old 10-27-2009 | 08:05 PM
Hydromotive sent me a 27P5 29'VR1 it has great slip factor but a 28 Bravo 1 got me better numbers as well better all around performance. I wish they would have put me into a quad with the rounder ears. I figured they knew better.The P5 gives transom lift single vees usually need better bow lift. Have 28 and 30 quads forsale if any interest,
PIT BULL is offline
Old 10-27-2009 | 09:30 PM
bbladesprops's Avatar
Offshoreonly Advertiser
Smile
Labbing the P5X is a wonderful acceleration advantage. (best part of the ending sum)
Rpm gains can be in the 150 WOT area. (not always reflective in speed)
I can't believe Hering would actually work on Hydros for more reasons than I have time to type. (that doesn't mean I don't like Hydro props, cause I do.)
Hydro rec. Lab........yeh OK
Julies' out of business.
Call us if we can help.
Brett
[email protected]
bbladesprops is offline
Old 10-27-2009 | 10:07 PM
CB-BLR's Avatar
Chris
Brett,
I live down the street from the Hering manufacturing shop in Marysville Washington. The production manager is a friend of mine. They have balanced, trued, sharpened, and tweeked, several different manufacturers props for me. I also run their props when doing poker runs.
Chris
CB-BLR is offline
Old 10-27-2009 | 10:50 PM
Smile
OK,
Hering doesn't typically work on competitive propellers for obvious reasons.
When I worked for and managed the Mercury Racing propeller Lab, we would only work on Mercury props. Now, I will and do work on all manufacturers propellers. We have put together templates and numbers for many manufacturers props with our own Labbing recipes as well as OEM numbers for standard geometry.
What matters is, the best performance your set up can achieve.
Take care,
Brett
[email protected]
