prop help >
prop help
prop help
Old 11-02-2009 | 11:32 AM
Registered User
Your are at 4-5 % with the 36's assuming all your numbers are correct. Maybe try a 34 or 35 5-blade and keep your motor a little under 5600...I think your fairly close...I'm sure your motor makes good power from 5200-5600 so anywhere in that range will be good. Good luck Rob
HTGMotorsports is offline
Old 11-02-2009 | 10:42 PM
Default prop
that great i'm going out wed more tuning.. wow my slip is there .
MOTION35 is offline
Old 11-02-2009 | 11:46 PM
Assuming that he has 1.5 ratio drives as well.
Here is a prop slip calculator
http://go-fast.com/Prop_Slip_Calculator.htm
I would just send the 36's to BBlades and tell him what you are looking for.
Griff is offline
Old 11-03-2009 | 10:47 PM
no I have 1.36 gears
MOTION35 is offline
