Polishing prop hub area,any advice?? >
Old 12-15-2009 | 09:26 AM
Originally Posted by bbladesprops
We use compounds from Formax as well as others when customers request the mirror finish.
Hi-Polish on blade area hurts performance. It looks great on the trailer during the 4th of July parade but increases slip under certain loads.
Each his own. Thats why we do it when requested.
Brett
Ut ooh! Performance loss??? Whos got a sand paper wheel?????
kreed is offline
Old 12-15-2009 | 10:49 AM
Racegirl3's Avatar
Easily Distracted
Since you guys wanted the camera moved up, I dont feel so bad now ..... I see a thread by Strip Poker saying "Polishing Prop" .......
and was a bit disappointed to find out it was in the prop talk section talking about polishing a prop ..... Geesh
Bad Girls Make Good Company
Racegirl3 is offline
Old 12-17-2009 | 11:25 PM
Strip Poker 388's Avatar
Rob
Wink
Im sorry for disappointing you.Ive been polishing on my shaft ,I just cant get it to come out. I need your help to really polish it out,just grab my nuts tight so you put a nice shine on it.
Attached Thumbnails Polishing prop hub area,any advice??-drives-019-large-.jpg
Strip Poker 388 is offline
Old 12-18-2009 | 07:27 AM
Racegirl3's Avatar
Easily Distracted
LOL - Nice.... Thanks!!
Old 01-04-2010 | 08:22 AM
Brett
I've known this for quite some time, but have never had a clear idea of what kind of finishing step I should use when cleaning a prop up at home (as they get polished by yse or come new that way...). what do you reccomend for props we don't need to send to you? Thanks!
wtfo is offline
Old 01-04-2010 | 02:53 PM
Rob
Most of the labed props iv seen look bead blasted.
Old 01-06-2010 | 08:17 PM
bbladesprops's Avatar
Offshoreonly Advertiser
Smile
No bead blasting; but rather wet grit rouge on a 18" buff wheel with the touch of a arteeeeeest who has done this for 25 years. That would be my business partner Bob. He has a SWEET final buff.
Racegirl..........Nice to have you on board here on the prop thread. We can use some spice.......................
wtfo, best clean up is to maintain the props throughout the season. If you trailer or put on a lift, rinse with fesh water and spray with light oil. Since this isn't always plauseable, you need to attack them at their own merit or situation. I mean do what you can when you can.
Satin finish will film up compared to HiPolish. HiPolish closes the pores a little more to prevent the iron in the 15-5 stainless from rusting. But, og to the satin for ultimate PERF.
Brett
[email protected]
bbladesprops is offline
Old 01-31-2010 | 09:22 AM
Brett
Hi Brett,
Looking at having my props done by Bblades this year, and figured I might as well go with the satin finish since its like free performance. If I rack store my boat that is used in fresh water is rusting of the props a minor concern? Or I should still always hit the props with some WD-40 or similar product? What kind of slip percentage differences or measurable m.p.h. changes have you seen between high polished props to satin finished props in a apples to apples comparison? Thanks in advance for any more info. on this subject.
johnny b good is offline
Old 01-31-2010 | 07:26 PM
Smile
Satin finish props have consistantly out performed HiPolished propellers. You will see more and more propellers done in the HiPolished relm because that is what folks want. Also, you will see better performance from the new props coming to the market. This is because the geometry changes are..........well better.
Most of these propellers will have a high polish to them. If these props were satin finished correctly....they would be 0 to 1 mph faster. This is the small but true performance gains from slight satin finishing.
B
[email protected]
Old 01-31-2010 | 09:41 PM
Velocity Vector's Avatar
Crazy Energy
My wife started out polished but she to is getting that satin look over time.
Velocity Vector is offline
