flo torque >
flo torque
flo torque
Old 01-26-2010 | 06:51 PM
markodessa's Avatar
Default flo torque
Can somone tell me the diference in a solid and a flow torque prop.
markodessa is offline
Old 01-26-2010 | 09:15 PM
ziemer's Avatar
The flo-torque style propellers have interchangeable hubs to fit different applications.
For example, with a flo-torque prop, you can run it both on a small shaft or fat shaft prop shaft with just a change of a sub $100 kit. For outboard applications, you can buy an OMC hib kit to run a Mercury prop.
A solid hub is a cast in place or welded in hub that is not interchangeable .
ziemer is offline
