What prop would be good? >
Old 02-10-2010 | 01:34 PM
Thumbs up What prop would be good?
Hey guys Im new to the boating world and have been reading about changing your prop for better hole shot, better top speed, a mix of both etc. I researched the current prop on my boat and wanted to know what the best prop I should have for the results I am looking for? It may be what is already on there?
Ok the boat is a 1985 Chris Craft Scorpion 210 with a 5.7l mercruiser V-8. Right now I have a Mirage Plus 3 blade, I'm not sure of the pitch on it though.
I am looking to do a little tubing and knee boarding but mostly just crusing around in the bay. I have had it out a couple of times since I got it last month and it seems like it takes a little bit to get on plane with 4 people on board. Any ideas would be appreciated, I have found general info on what is good and what props do what but nothing boat specific. Just looking for some more insight!!! Thanks guys!
85scorpion is offline
Old 02-11-2010 | 08:29 AM
For what your wanting to do you need to first find out what pitch prop you have now and have it repitched down buy one. That will give you a little better hole shot for about 150.00.
plumb crazy is offline
Old 02-11-2010 | 09:25 AM
AIR TIME's Avatar
merc rev 4 blade should work call brett at b bladdes, but 1st you need to know what prop you have. I bet a 19p.
AIR TIME is offline
Old 02-11-2010 | 09:27 AM
How would I find out with pitch it has? Will it say on it? I haven't gone to look at it closely...
Old 02-11-2010 | 10:36 PM
Should say on the side of the prop or inside the hub. Most likely it a 19 or 21p
stoltz is offline
Old 02-16-2010 | 06:14 PM
I went by and checked the prop today and I do have a 19p. What would be the best upgrade to go from there? Thanks for any input!
Old 02-16-2010 | 07:04 PM
Id say the Mirage plus you have is your best all around prop
HTRDLNCN is offline
Old 02-17-2010 | 05:15 PM
I had a 21 Chap that came with a 19p. I changed it to a 21p 3 blade. I tubed and skied behind it all the time with know problems. I could even pull up two guys on slalom ski. It had a 5.7 260 hp.
capt2130 is offline
Old 02-17-2010 | 06:46 PM
Sounds like you may have the correct prop. What is the RPM at WOT trimmed out for max speed?
jeffswav is offline
Old 02-17-2010 | 07:20 PM
bbladesprops's Avatar
Offshoreonly Advertiser
Smile
Call us and we can send you a Revolution 4 for testing.
Brett
[email protected]
bbladesprops is offline
