HELP!! prop for a 28 scarab with a blown 525sc???? >
Old 04-04-2010 | 05:47 PM
Red line is 6000 on the motor.
justincasey57 is offline
Old 04-04-2010 | 08:39 PM
try a 19 pitch mirage not a plus .and what about your speed are you useing a gps or reg speedo?????
bajabob is offline
Old 04-05-2010 | 05:22 AM
He's using his gps on his iphone he dont have a gps speedo and the speedo in boat. A buddy of mine seems to think a 23p 3blade bravo or something along those lines.
Old 04-05-2010 | 08:47 AM
My buddy tried my 26p 4 blade bravo prop and said at full throttle it was at 3100 rpms? He put his 20p 4 blade prop bak on and ran 5100 rpms at around 60mph? Something isn't making sense. Can anyone help?
if you are runnig a20pitch 4 blade thats the same as a 21pitch 3blade so you will trun 5100to 5200rps with that 21. 1 pitch is 200rpm to 300rpm depening on the make of prop so if you go to a 19 you will trun 5500rpm . if you put a 23 your rpm will 4700.now you going the wrong way with your rpm .. . go with the smaller prop you will see more speed your rpms have to be higher !!!! so the motor is in its power band .. if you had 150 gears in your drive you would be puting bigger prop on like the other guys but you have 136 you have to use a smaller prop . i had a 454 with 450hp i was runnig a 150drive with a 25pitch mirage i switch to a 136drive i had to go down to 21 plus pitch doing 66.5mph then i put a 540dart now i am runnig a 23pitch and runnig over 80mph . i hope this help you out ??? good luck
bajabob is offline
Old 04-05-2010 | 11:49 AM
bbladesprops's Avatar
Offshoreonly Advertiser
Smile
Again, if you need to obtain some test propellers, let us know and we can offer some asistance.
Brett
[email protected]
bbladesprops is offline
Old 04-05-2010 | 12:04 PM
6000rpms????????? Why???
If its just a 525SC with a chiller and pulley upgrade, then max rpm should be about 5300rpms. The stock rev limiter comes in at 5350rpms.
Something really does not make sense. How much HP was his last engine and what rpm/speed did it spin at???
I had almost the same engine in my 28 Pantera, just no chiller, but I had a roller cam. With a 1.5 drive I could spin a 26 Bravo prop to 5300rpms. With a 1.36 that would equal a 22-23 pitch prop.
Griff is offline
Old 04-05-2010 | 12:59 PM
I'm not sure why the red line is 6000 bu that's what he told me. The guy ho installed the motor art te timing at 8degrees when he installed I for my buddy. My buddy has now talked to the guy who sold him he motor said it should be at 34 degrees total timing at 4500rpms. Sound right??
Old 04-07-2010 | 07:28 PM
Brett my buddy ben tried to get in touch with you several times and brad was suppost to get you to call him back. If you can call him anytime he needs to get with you about a prop. Ben 770)294-8072
Old 04-07-2010 | 08:57 PM
Smile
Please try us tomorrow.
I just spoke to Brad and he was waiating for more performance information from you.......per your last connversation with him.
Let us know what you found out.
Brett
[email protected]
Old 04-08-2010 | 12:59 PM
Does anyone know more info on these motors? As far as what the timing should be? What rpm range it should be at?(my buddy was told by the guy who sold it to him thAt the rev limit was 6000. He's hitting 5200 with the 4 blade 20p at 58-60 mph sounds right to me but just needs to change to a 3 blade not a 4 blade. Any help is greatly appreciated.
