-   Prop Talk (https://www.offshoreonly.com/forums/prop-talk-165/)
-   -   Prop For Pulling Toys (https://www.offshoreonly.com/forums/prop-talk/230223-prop-pulling-toys.html)
vindicator101 05-10-2010 08:08 PM
Little opposite for this forum but I hope with all the prop knowlege on here someone can help. I'm looking for a prop to use when I pull small kids on a tube or pull wake boarders. I have a 24ft VIP Vindicator probably around 4000lbs with a single 496HO. Right now I have a 24p 4blade(reworked to 23p) which works well all around but I'm not on plain at the speed a need to be(20MPH)for pulling toys. I don't care about anything but getting out of the hole quickly and holding low speed while using this prop. Thinking of buying a Merc High Five 19p. Does this sound about right or does anyone have other suggestions? Thanks.
FIXX 05-10-2010 09:32 PM
Fixx
turbo 2+2th,all my customers use this prop for water fun,,great hole shot and keeps the boat on plane at lower speeds..
i reccomend a 22 pitch..
http://www.turbo-props.com/products/...th-series_th22
vindicator101 05-11-2010 06:32 PM
Thanks for the info.... But wow, 22 pitch? I wouldn't have thought that big. Even if I don't exacly jump out of the hole now with the 23p? Is it possible to go too small in pitch? If so, what would happen, bow out?
bbladesprops 05-11-2010 09:05 PM
I would look at the 19-21 Revolution 4. These props will get you on plane quick with little bow rise and not compromise top speed by that much. You will be able to stay on plane at the lowest speeds you have seen. I think testing one will help you to decide what fits your boating style and goals. Call us and we can answer more questions and send you a prop to test without having to buy it. We also have the 2+2 props for testing but, I think you'll like the bigger diameter of the Revolution 4.
Brett
vindicator101 05-11-2010 09:39 PM
Thanks Brett, I'll call this week... Keith
vindicator101 05-14-2010 02:49 PM
Bblades, called and talked to Brad today, he got me set up with one to test. Thanks, Keith
bbladesprops 05-17-2010 11:24 AM
Let us know how the testing goes.
Brett
