23 3blade vs 24 4 blade >
Old 06-24-2010 | 01:42 PM
Default 23 3blade vs 24 4 blade
What would the diff be If I put a 4 blade 24 on my 257 pq bravo 1 setup. I currently have a 23 3blade. Will it holeshot better but lose top end? I've got approx 450hp 454 & will hit 5000rpm
paintman is offline
Old 06-24-2010 | 02:01 PM
randy carlson's Avatar
I am no expert but I went from a 25 3blade to a 24 4blade and was very happy(311formula), I could hardly get on plane in 2foot waves with the 3 blade, 4 blade hooks up everytime no matter the conditions gave me higher cruise speed with less trim tab input required for any conditions, I ended up about 2 mph slower but it was well worth it gave me the same WOT RPM if you go up in pitch I think it will considerably knock off rpm depending on what prop you go to good luck Randy
randy carlson is offline
Old 06-24-2010 | 02:09 PM
Go down in pitch if you go to the 4 blade.
kwooley is offline
Old 06-24-2010 | 02:36 PM
What about around the docks? Easier or.......
paintman is offline
Old 06-24-2010 | 03:53 PM
Ive got the same boat you do (less power--385 hp) and just switched to a Hydromotive Quad IV 23 pitch and love it (turning 4600 rpm). The quad iv is a perfect prop for the legend--I would think a 24 pitch would be about right for your setup.
Powerquest_Baby!! is offline
Old 06-24-2010 | 04:24 PM
the answer to your question depends an awful lot on which 3 and 4 blade prop you're talking about...
wtfo is offline
Old 06-24-2010 | 07:25 PM
my best numbers.272 baja 496 HO.mirage 23+ 5050 at 66.4 bravo1 22 5150 at 64.5 bravo1 24 64 at 4775 hope it can help.
zx14k is offline
Old 06-25-2010 | 06:14 AM
zx, lab that Bravo 24 for more rpm and more speed as well.
verbi69 is offline
Old 06-26-2010 | 05:02 AM
the 3 blade is a power tech and the 4 blade is a bravo........i think
paintman is offline
Old 06-26-2010 | 11:50 AM
what speed can i expect with the 24 lab.
zx14k is offline
