how to measure a prop ? >
Old 07-31-2010 | 01:21 AM
Default how to measure a prop ?
is it possible to measure a prop with a measuretape or how should it be done?
thanks
danteknik is offline
Old 07-31-2010 | 08:00 AM
tmdog's Avatar
We are talking dia. right? Measure from end of blade to center of hub. Multiply by 2 = dia.
tmdog is offline
Old 07-31-2010 | 05:16 PM
thx
but actually i was looking for how to measure the pitch.
Old 07-31-2010 | 08:42 PM
Originally Posted by danteknik
thx
thats a tuff one...i guess u need a laser ( special tool ) to do so ....?????
DareDevil is offline
Old 08-01-2010 | 06:55 AM
throttleup's Avatar
Utilizing a: Pitchometer, Pitch blocks, Prop Scan or MRI typically.
Julie
throttleup is offline
Old 08-01-2010 | 08:27 AM
tmdog's Avatar
Julie
Does Home Depot stock those items?
tmdog is offline
Old 08-01-2010 | 09:23 PM
bbladesprops's Avatar
Offshoreonly Advertiser
Smile
You can measure diameter via tape with 4 blades since you can go from one tip to the other. Multiple blades require other tools.
Pitch is interesting because you have various points of measure that must be averaged. Rake is another story and you must have the special computer stuff we use. However, I used to do it with a protractor.
We have the pitch blocks, mechanical tools, HALE HRI, and all the other stuff needed to let you know what you have in posesion.
We don't charge to look at your props other than to have you send them in. Let me know if you have any questions we can answer.
Thanks, Brett
[email protected]
bbladesprops is offline
Old 08-06-2010 | 08:15 PM
Typically all props are marked , if you look in the center of the hub, in many cased it will be stamped on the inside of the propella just under the nut and locking washer.
Also the side of the prop is stamped with 1/8 " tall letters, often painted over and the paint fills in the indents on the propella. Take a hard look at it with a magnifying glass.
What do you want to do with the propeller? Do you want it reconditioned? Are your RPM's too high? You could send it out for reconditioning but you need to figure out where you want to go, less RPM's more RPM's ect .
Good luck
Brian
Big Boys Toys is offline
