What PROP ? >
What PROP ?
What PROP ?
Old 08-16-2010 | 07:55 PM
Default What PROP ?
what would be the best prop for my boat? 28 ft power boat running single 350 hp diesel 1to1 and surface drive? does any one have any ideas?
baja89drc is offline
Old 08-16-2010 | 09:05 PM
What is the max rpm for the engine?????
Griff is offline
Old 08-17-2010 | 05:26 PM
3200 rpm
Old 08-17-2010 | 08:43 PM
I would figure its a 55-60mph or so boat with that power. I would guess something in the 24 pitch range, but that can also be affected a lot by prop diameter.
You can plug and play with some numbers here http://go-fast.com/Prop_Slip_Calculator.htm
and here http://go-fast.com/boat_speed_predictions.htm
On a 28 single engine V bottom, I would expect slip to be 14-18%
Griff is offline
Old 08-17-2010 | 09:22 PM
Thanks for the help.
Old 08-22-2010 | 08:29 PM
bbladesprops's Avatar
Offshoreonly Advertiser
Smile
When and if you get frustrated...........
Call me and I'll do my best to get you focused in the right direction.
It can take time to dial in a application like yours.
B
[email protected]
bbladesprops is offline
