labbed p5x >
labbed p5x
labbed p5x
Old 08-24-2010 | 08:40 PM
crayolacrazy's Avatar
Default labbed p5x
has anyone labbed a p5x what where the rpm gains speed and cost
crayolacrazy is offline
Old 08-24-2010 | 11:41 PM
CB-BLR's Avatar
Chris
I have had P5x's labbed by both Hydromotive and Hering. They gain about 150 rpm with a standard balance, blade equalization, and sharpening. They then generally turn about the same rpm as a a 1" smaller pitch P5x, but with more speed.
ie.. a labbed 28 P5x will spin about the same rpm as a stock 27 P5x, but with more speed.
What I usually do is find the P5x that does the rpm I want it to do, and then buy the next inch larger, and have it labbed... it then generally picks up both midrange criuse speed and top end speed over the smaller prop. (about 2 mph)
Just my experience,
Chris
P.S. I live just down the street from Hering.
P.P.S. My boat is the fastest with a Merc Lab Bravo
CB-BLR is offline
Old 08-25-2010 | 08:17 PM
What is the major advantage or disadvantage with going to the 5 blade vs lets say a Bravo 1 4 blade??
verbi69 is offline
Old 08-26-2010 | 12:22 AM
Rebel_Heart's Avatar
Usually better mid-range with a 5 blade and most find a couple up top. If you're buried deep the 5 blades are harder on the drives.
Rebel_Heart is offline
Old 08-26-2010 | 05:21 PM
bbladesprops's Avatar
Offshoreonly Advertiser
Smile
We see the same improvements Labbing them here at BBLADES.
Bravo 1 props are typically faster than 5 blades un less the boat has very high slip or a completely rearward CG. Then the 5 blade props fix these issues.
The reason 5 blades are popular is the "X" dimentions are so high these days, you often need a 5 blade just to get on plane. Also the cruise speeds are generally better than with 3 or 4 blades.
Brett
[email protected]
bbladesprops is offline
Old 08-26-2010 | 08:43 PM
I would love to try a 5 blade on my boat.
Aprox. 570 hp, would like to spin 5300.
Boat is large in my opinion for a single engine application.
verbi69 is offline
Old 08-30-2010 | 07:49 PM
Smile
verbi69,
Call us and we'll make it happen.
Brett
[email protected]
Old 08-31-2010 | 05:14 PM
Will do Brett, the engine is out of the boat right now for pistons. I'll call when I get it back with some base numbers.
verbi69 is offline
Old 09-01-2010 | 11:50 AM
Originally Posted by bbladesprops
verbi69,
Brett
Do you have Hydromotives in the test program?
RaggedEdge is offline
Old 09-01-2010 | 12:28 PM
Brett have you had any experience with a DCB FX28 vee bottom?
heater63 is offline
