-   Prop Talk (https://www.offshoreonly.com/forums/prop-talk-165/)
-   -   3 vs. 4 blade props (https://www.offshoreonly.com/forums/prop-talk/242092-3-vs-4-blade-props.html)
msg16428 11-07-2010 05:06 PM
3 vs. 4 blade props
3 vs. 4 blade props, what are the advantages and/or disadvantages of each?? Just boguht a 1998 scarab 29 with twin 350 carb engine what prop do you guys recomend for this application?
billeickmann 11-15-2010 03:24 PM
Generally, three blade props work better on non-stepped hulls with drives that are not mounted too high. Four blades work better on stepped hulls. What prop are you running now at what rpm and speed?
cigboat1 11-15-2010 03:50 PM
23's are the better way to go... three blade.
Jim
You might want to try a 23 -3 blade cleaver also, litte tougher to get on plane but they will work and might give you a few M.P.H.
