volvo 290 props >
volvo 290 props
volvo 290 props
Old 12-08-2010 | 11:58 AM
its a hydromotive nose cone water pickups are in the same place my power range is 5000 to 5500 rpms
innerrage is offline
Old 12-08-2010 | 03:07 PM
mattyboy's Avatar
if the rpm range is 5000 to 5500 stay away from the 23 solas maybe the 21 solas would be worth a try . the 26 i have will most likely drop your rpm to low too.
mattyboy is offline
Old 12-10-2010 | 11:12 PM
sounds god if i could find one to try before i buy one
Old 08-15-2011 | 06:14 PM
Hey Guys, Im looking for some advice on the Titan Prop.
My boat isn't quite the missiles many of you have but it seems there is quite a bit of knowledge among the members which could help.
I have a ALMAR Sounder 24' with a Marinepower Diesel 275Hp @3800rpm VOLVO290sp 1.61 Leg, Boat loaded is around 6000lb
The original Prop I had was a OEM elephant ear16 x 21' which gave
Cruise 3000rpm 44kmh GPS
Max 3800 60kmh GPS
This to me worked out around 25- 30% slip
The prop had been in the wars so I purchased the VOLVO16x 23' Prop. This gave much better fuel economy but pretty much the exact same speeds/revs, at larger slips???
The Issue is now I have Hit a few logs and the prop is a mess, So I would Like to try the Solas Titan.
Should I get the 21p or the 23p as it sounds to bite better even with slightly less diameter.
Downsouth is offline
Old 08-15-2011 | 06:18 PM
Whoops double post
