Need more stern lift >
Old 11-29-2010 | 11:16 AM
Default Need more stern lift
Still paying with props on my 22 Center Console and need more stern lift. I have a 24 pitch stock Bravo One that works well but runs a little nose high. What style prop would give me the best stern lift? This is an outboard application.
Maritime_Eng is offline
Old 11-29-2010 | 11:32 AM
A Rev 4 or Hydromotive Q4 will give more stern lift.
Griff is offline
Old 11-29-2010 | 12:38 PM
bbladesprops's Avatar
Offshoreonly Advertiser
Smile
I like the Q4. Also, a slightly modified P5X could work great if mid range cruise is the main goal. (We would decrease the diameter and blade area)
Brett
[email protected]
bbladesprops is offline
Old 11-29-2010 | 12:55 PM
Brett
Yes Mid range cruise is the main goal. If Im running a 24 Bravo now, what would I run in a Q4?
Old 11-29-2010 | 01:55 PM
I have 2 Q4 26 pitch for a 1 inch bravo 1 drive if you want to buy them. I don't know if they will fit outboards.
UrbanDisturbance is offline
Old 11-29-2010 | 02:00 PM
Smile
The Q4 will pull the R's down slightly due to truer pitch and wetting more of the hull. So, use that and your current rpm to decide.
Brett
[email protected]
Old 11-29-2010 | 02:19 PM
Thanks but that might be a little too much for me. Im guessing I would need a 23pitch.
Old 11-29-2010 | 08:51 PM
Brett
How does the Rev 4 from mercury compare to the Q4 from hydromotive?
Old 11-30-2010 | 12:16 PM
Smile
A touch smaller in diameter with 5 degrees more rake angle (bow lift). Also the cupping is a little stiffer. The Rev 4 will give better overall lift where as the Q4 will give better stern lift.
Why not test them? Call us and we can arrange this.
Brett
[email protected]
