finding the right prop for my 221 liberator
#31
Probably will be labbing my props in winter depending the props I am testing Saturday.
#32
OK, bringing back another old thread, I have two props to try while on vaca this week, a 21 Enertia and a 19 Tempest but the hub kit that I was sent does not work with my drive
part number i have is 835265Q02 which is for "Flo-Torq II Hub Kit - Johnson/Evinrude OB & OMC Sterndrives w/ V6, V8 gearcases, Cobra & King Cobra sterndrives 1991 & Newer"
the spacer is 1/2 the thickness of the OMC part on my boat now which is causing interference, if I run try the OMC spacer I do not have enough spline at the enf of the shaft for proper mounting
so my question is what Flo Torq hub kit are you guys using to run Merc Props??
