Prop size ?
Usually when you add a blade, you go down 2 pitches. You are removing a blade, so I would think you need to go up 2 pitches. Nevertheless, your image shows you have a Cigarette. I don't think you want to go with a 3 blade. BBlades has a trial program.
Urban has a good point there. A thing about the Bravo is, that the true pitch is more like 23". So with one less blade and the smaller dia. of the Mirage, a 25" should hit the same rpm's+/- a bit. What is your goal?
