Help with Prop choice  29 Fountain >
Old 05-10-2011 | 05:08 PM
Default Help with Prop choice 29 Fountain
I have a 1995 Fountain with a stepped bottom. Running twin 500 HP's with CMI headers and Bravo 1 Imco EXtreme Advantage drives and Imco 1" shortys. What props and pitch do you guys think I should start with? Anybody with close to this set up? I have a chance to buy a set of 27P 4 Blade Hydromotives at a steal of a price, yes, no, maybe. Thanks.
Osageparty is offline
Old 05-10-2011 | 06:17 PM
What do you run now? Speed rPm? Gives us some numbers. The 27p sounds good but you need to see what has been done to them.
GTOFFSHORE is offline
Old 05-10-2011 | 07:11 PM
This is a new install. I don't have any numbers to go on. I just need to know a good starting place. Hoping somebody with close to the same set up or maybe somebody with a crystal ball could help out. LOL I don't imagine I'll get it right the first try but hopefully close. Thanks.
Old 05-11-2011 | 01:58 AM
Twin 500's in a 29 is going to need more than 27" props. Probably at least 30's or 32's........assuming you have 1.5 drives.
Griff is offline
Old 05-11-2011 | 07:27 AM
rgrgoog's Avatar
I am running 502's with B&M Blowers (est HP 575-600hp/engine) and I turn 30p 4 blades to 5200 easily. Fully loaded with fuel (155 gal) and one other person I get about 85-87 mph out of her. 1/4 tank of fuel and light load she will be in the low 90s (90-93). I am running XR drives (1.50 gear ratio).
rgrgoog is offline
Old 05-11-2011 | 10:28 AM
Thanks for the input. I will pass on the 27P's and will look for a set of 30P's. Sounds like a good place to start.
Old 05-11-2011 | 05:34 PM
bbladesprops's Avatar
Offshoreonly Advertiser
Smile
Call us and we can send you a set of 30 stock B1's to test with. The cost to do so is $90 and there are no strings attached. If like them you can buy them, if not we can discuss the findings and you can send the props bck.
Brett
[email protected]
bbladesprops is offline
