Prop Selection >
Prop Selection
Prop Selection
Old 06-16-2011 | 11:28 PM
The bravo 1 will handle better for sure.
Racerryan is offline
Old 06-17-2011 | 04:05 PM
Ok so I think its safe to say that everyone agrees that I should be running between a 24p and 26p. I would love to get the most topend but, im not sure its worth getting proped for topend because where I go boating I cant keep it wide open too long unless the conditions are perfect. Up here around cape cod we usually get heavy surff. On average how much speed do you loose going from a 3 blade to a 4 blade? And a 4blade would be better for what......low end...mid range? And lastly after the procharger installation should I be running a solid hub?
bajaboy217 is offline
Old 06-18-2011 | 01:56 AM
Our Hammer is 2mph slower with the Bravo 1. The Mirage + is more stable on top end but does not stay hooked up in tight corners like the Bravo 1. They have the same slip numbers all the way through the rpm range. Both are labbed.
Old 06-19-2011 | 01:29 PM
How do you know which prop to run if you do not how how many rpms you will turn the current prop with your power adder? A lot of theory but IMO I would buy a prop after I upgraded and get some information from what you have now. I had a problem as well selecting the right prop but went with the theoretical propeller guides online after gathering my data and backing it up with recommendations posted in the forum thereafter...
jctexas07 is offline
Old 06-20-2011 | 11:27 AM
Jctexas07...Sounds logical, But I was just looking to save time and see if any one out there had this setup so I could see what worked and didn't work for them. So far I have not bought or decided on a prop and the procharger is getting installed in a few day's. I might just wait and run the 21p that I have now and check the speed and rpm then bring the results back to the forum.
Old 06-20-2011 | 01:37 PM
I have a Bravo One stamped as a 25P. PM me if your interested.
Itsallgood995 is offline
Old 06-21-2011 | 06:45 PM
I know when I was selecting a prop, I wanted to make sure I was getting exactly what I needed. The numbers I got from my initial run with the advice here paid off bigtime. I researched and called and thought it through logically...if you are anything like I am, I wanted the first upgrade to be the right one. I will be excited to see what you get with your power upgrade.
Old 06-26-2011 | 08:10 PM
ProCharger is in, took it for a test ride, needs minor tweeking.... still running the 21p mirage + getting 50.5 mph half throttle and hitting the rev limiter at 4650. How much should I go up on the prop?
Old 06-26-2011 | 09:24 PM
what Rpms are you callings 1/2 throttle. I pushed my 21p m+ to 50 mph at arount 4100 rpms! How hard are you hitting rev? with drive still neutral or raised or even tucked??
I was hitting rev with my mag 385hp and moved up to 23p m+.. I would say 23p m+ and it will give you good indication whether 24p b1 or 22p b1
if hitting rev hard.. would go straight to 24p b1 or 25p m+
loaded, I can only push 24p to 4700
hope this helps based on my trials with 454 mag
nailit is offline
Old 06-27-2011 | 03:19 PM
Nailit,
I was at 4650rpm at half throttle with the drive in the neutral position and got the gps reading of 50.5. As soon as the rev limiter kicked in I pulled back on the stick. Before I added the procharger I could be at wot with the drive high enough to start seeing a rooster tail before I hit the rev limiter with a top speed of 56. My engine's operating range is 4200-4600rpm. On the factory gage im at 4650 when the limiter kicks in.
