280 pq with 454 mag prop helphelp >
Old 07-05-2011 | 01:50 PM
Default 280 pq with 454 mag prop helphelp
OK so looking at the boat an while the owner was driving in very rough water we were doing 60 at what looked like 6000 rpm??? Is this odd. Also very slow coming outs the water. I believe it has stock 4 blade prop. Stock motor. What can I do to get outa water faster an is that a normal rpm for the boat?
dra200832 is offline
Old 07-05-2011 | 02:09 PM
Dave M's Avatar
Veteran: Navy
Is it a 454 Mag MPI? If so, the rev limiter is set at 5150 RPM. Something does not sound right.
Dave M is offline
Old 07-05-2011 | 02:16 PM
Yes it is a mpi. I could be off on the rpm. But it was Sunday at loto very very rough water. Super slow coming out of the water. But once on plain it took off good
Old 07-05-2011 | 03:26 PM
Is the boat pink purple and teal. For sale at Kellys Port? If so it was mine a couple years ago.
diggin H20 is offline
Old 07-05-2011 | 06:54 PM
bbladesprops's Avatar
Offshoreonly Advertiser
Smile
Specific performance numbers as well as the gear ratio and the exact propeller modal is needed to send you in the best direction.
Brett
[email protected]
bbladesprops is offline
