props for 32 sunsation with 600's >
Old 08-10-2011 | 02:53 PM
Default props for 32 sunsation with 600's
currently running 32 pitch maximus 5 blades with the diffusers cut down ( these came with the boat) spins up to 5700. thinking of going to 34s. would 5 blade Herrings be a good option ? boat could use some bow lift I think
thanks
MIlander is offline
Old 08-10-2011 | 04:15 PM
thanks
5700 rpm's. Are those 600's stock?
A.O. Razor is offline
Old 08-10-2011 | 04:27 PM
I believe they are stock and the rev limiter should be 5400 but both tachs go to 5700 at WOT. either it was reflashed or the gauges are not accurate? just got Diacom software today and will scan them this weekend
MIlander is offline
Old 08-13-2011 | 01:29 PM
scan shows both engines with .15 hrs greater than 5499 rpm
so tachs must be accurate. anyone have any suggestions regarding which props I should try? I think the boat needs bow lift would Herrings be a better choice?
MIlander is offline
