28 pantera prop >
28 pantera prop
28 pantera prop
Old 08-30-2011 | 10:23 PM
Default 28 pantera prop
i have a 96 28 pantera. im looking to get my prop slip lowered. with a 26 bravo 4 blade at 5500 rpm im getting about 65 mph. thats about 29% prop slip!!. i have a high x dimension due to my notched transom but i have a 3 inch spacer in the drive to put me back to about 2.8" prop centerline below the transom. any one have any input ??
88bullet is offline
Old 08-31-2011 | 11:28 AM
big shaft or small shaft on bravo 1 , i have spinnille and some hydrs around
fastscarab22 is offline
Old 09-07-2011 | 07:18 AM
small shaft bravo.
88bullet is offline
Old 09-07-2011 | 04:12 PM
Private message me and we can get you the prop
Old 09-08-2011 | 12:39 PM
Rob , At HTG has 2 28 hydromotive you could try first if you want
Old 09-08-2011 | 01:45 PM
I have a 24P Maximus in the classfied that may work for you. The slip was a lot lower w/ it compared to a Bravo one I tried.
Itsallgood995 is offline
Old 09-08-2011 | 06:42 PM
Have you done those searches I recommended in the Pantera section?
Call Jo
tomcei is offline
Old 09-09-2011 | 02:26 PM
bbladesprops's Avatar
Offshoreonly Advertiser
Smile
In the past we have had great sucess with Bravo 1 props set at lower depths but 5 blades can help in this situation. We have different 5 blade and 4 blade props for testing if you decide.
Let us know if we can help with anything.
Brett
[email protected]
bbladesprops is offline
Old 09-10-2011 | 12:39 PM
Check the bottom for for some hook. It had about 1/8" when I had it, but the trailer was not really ideal since the outside bunks were about 6" too short.
The propshaft should be about 4.25" below the bottom with the 3" spacer with the drive trimmed to neutral.
Griff is offline
