-   Prop Talk (https://www.offshoreonly.com/forums/prop-talk-165/)
-   -   29Mirage to 29M+ differences? (https://www.offshoreonly.com/forums/prop-talk/262549-29mirage-29m-differences.html)
ndaniels 09-18-2011 09:11 PM
Just tried out an old school solid hub 29 Mirage.. loved the handling but need more pitch.
I know the newer 29 Mirage+ are odd ball props from everything I"ve read and I have no idea how the old mirage compares to the newer +, so I'm hoping to find out.
tmdog 09-19-2011 09:06 AM
M+ is cupped and the other isn't.
Stating from what I read.
BBB725 09-19-2011 06:02 PM
Mercury told me that the 29plus could be called a 31, it's a big prop to turn
ndaniels 09-19-2011 08:21 PM
Thats also in line with what I've heard.. just didn't know if the older 29 was actually a 29P prop.
bbladesprops 09-20-2011 04:55 PM
Old prop is stiff too but the 29M+ is like 30.5 pitch compared the family.
Brett
ndaniels 09-20-2011 05:43 PM
Brett
Thanks Brett!
I was hoping you'd see this. Are you able to pitch up the 29m+ at all?
bbladesprops 09-20-2011 08:10 PM
We can.
We do it by hand because there isn't a 30-32 pitch pitch block for the Mirage or M+ family. Noboby ever made one that I am aware of. We never had one at Mercury or Mercury Racing (things changed and we re-focused). However, we have done this in certain situations (at BBLADES). Situations that need the 3 blade personality and use the gear ratio and HP that need big 3 blade pitch sizes
Call us and we can discus the options.
Brett
bajabob 09-21-2011 02:10 PM
i try a 23mirage then a 23+ the plus trun 5000rpm the 23 trun 5200 so 200rpm was the diff got the same with my 25mirage . the plus i lose top end ,but gain midranges. the 23 i gain top speed , but lost midrange . i hope this helps you out good luck:drink:
