Looking for 6 or 7 blades >
Old 10-04-2011 | 09:39 AM
Default Looking for 6 or 7 blades
I have a 42 Fountain Poker Run with 525's and I need to get a set of 6 or 7 blades. Cant seem to find anyone that has either used or new in stock.
What pitch do you all suggest. I have heard 32 on the 6b's and 31 on the 7b's
rockstar38 is offline
Old 10-06-2011 | 07:59 PM
bbladesprops's Avatar
Offshoreonly Advertiser
Smile
First, we need more info on your boat to suggest number of blades, and pitch options. Drives and the gear ratio will help too.
Why do you need 6-7 blade props.
We have 28-40 inch pitch 5 blade props at 17 inch diameter in stock in 16 and 18 degrees of rake. If your boat is set up right these props will work. No doubt.
You will find few locations with 6-7 blade props on the shelf, manufactures included.
Of course we can supply you with anything you desire.
Call us and we will do what we can to help.
Brett
[email protected]
bbladesprops is offline
Old 10-07-2011 | 01:26 AM
So that when he throws blades, he will still have 5 left
Rocky, did you ever try some 1/2" or 1" drive spacers????
Griff is offline
Old 10-09-2011 | 06:53 PM
i can only talk about one poker run 42 that was around the new england area in a couple fountain dealers same boat just moved around it was an 06 first year they came out and it had 525 its with sport master -2 drives 136 gear ratio running 28 pitch 6 blade herings.92mph .
47 lightning is offline
