Prop advice >
Prop advice
Prop advice
Old 12-14-2011 | 12:50 PM
Default Prop advice
Hey guys,new to this site but a long time member of THT.I would like to get some of your opinions on what props you think i should be runnin.Ive got an 88 25ft contender enclosed transom with a twin stainless marine bracket.Mounted on the bracket i have twin yamaha 200 hpdis with Merc Bravo 1 22 pitch 4 blades.Right now i am getting about 5000rpms at 50 mph with this setup.Motors could come up two more holes but they look like they are pretty close to where they need to be.Cav plates are not burried.What would be your advice for the best 4 blade and 3 blade.The recomended RPM range for these motors is between 5500-5700.Every response that i can get will help out greatly.Thanks
foster6656 is offline
Old 12-14-2011 | 01:29 PM
Try the rev 4. It's a great outboard prop comes in smaller sizes and give better all around lift.
GTOFFSHORE is offline
Old 12-14-2011 | 03:59 PM
+1
Rev4 in a 19". Remember that your B1 22" is really a 21" true pitch.
You could also try the Tempest+ and Mirage+.
A.O. Razor is offline
