BBLADES Winter Special >
Old 02-14-2012 | 02:10 PM
INDY27's Avatar
I have one bent blade on a Bravo 32, how much?
Attached Thumbnails BBLADES Winter Special-bravo-32-001.jpg   BBLADES Winter Special-bravo-32-002.jpg
AUTOCONNECTIONLLC.COM
INDY27 is offline
Old 02-15-2012 | 05:24 PM
INDY27's Avatar
Roughly?
INDY27 is offline
Old 02-15-2012 | 08:27 PM
Originally Posted by bbladesprops
Again a reminder that the winter special ends in 27 days. Any propeller recieved within the month of Feb. will recieve the winter discount pricing.
Thank you,
Brett
On the way for fresh up Brett. Thanks
laszlo01 is offline
Old 02-16-2012 | 03:16 PM
formula 382 sr-1, send the props in to insure they are here before the end of the month. We can discuss the issues via phone as soon as they arrive.
Thank you,
Brett
Props are on the way, They will be there on Tuesday UPS !!!!
Joby,
formula 382 sr-1 is offline
Old 02-20-2012 | 06:23 PM
sending my props out tomorrow from michigan...
bigfarmer is offline
Old 02-20-2012 | 07:11 PM
1 MAIDEN AMERICA's Avatar
OUCH!
How did that thing live? I cracked 4 stock 32's, without hitting anything.
1 MAIDEN AMERICA is offline
Old 02-22-2012 | 12:44 PM
bbladesprops's Avatar
Offshoreonly Advertiser
Smile
indy 27
Somewhere around $160.
We fix those types of issues often. Correct heat and experience is what it takes.
Thank you,
Brett
[email protected]
bbladesprops is offline
Old 02-22-2012 | 09:48 PM
Brett, I have only run my boat, a Fountain Fever 29' with twin 6.2s twice before I had to put her away for the winter (new boat to me - 160 hrs.). It has Bravo I 26 pitch props. I want to run it this spring with a full tank to see how many r.p.m.s it pulls. If my memory serves me correctly it pulled about 5100 - 5300 with an indicated 3/4 tank and just me aboard. If the boat currently pulls an honest 70 m.p.h. on the GPS speedo what speed increase would it gain (on an average) with the Bravos getting your lab treatment? Seems like blueprinting the props will be the most bang for the bucks. Might even get a bit of return on using less fuel? I have no plans to increase horsepower.
Wes Burmark is offline
Old 02-23-2012 | 10:32 AM
Smile
Wes,
Labbing props is definately one of the biggest bangs for the money.
In your case, you will need to check on your desired WOT rpm. I believe you are already there unless the engines are set up with higher rpm capacity than normal.
If you are already at the top rpm you desire, we would go to the 28 pitch castings and Lab them. That process could reap 2-5 mph across the rpm range and most likely in the 3.5 mph range. Also you will recieve butter smooth operation and acceleration.
Call me anytime and we can discuss this more in depth.
Thank you,
Brett
[email protected]
Old 02-23-2012 | 11:46 AM
Brett, I will call you after I test my Fountain this spring. Thank you for your quick reply.
Just one more quick question. "IF" I find I am at or near the top end of the rev range with my Bravo I 26" pitch props is there anything you can do with that specific prop? The reason I ask is that I purchased a spare set of LH and RH props when I bought the boat. I knew nothing of labbing props at the time. Or would I be better off selling the Bravo I 26s and getting 28s for you to work on? Needless to say I am trying to keep costs down. Do you take trade-ins?
