looking for a broken #6 prop
im looking for a #6 prop that is damaged beyond repair. doesnt matter how many blades it has , can be cracked, missing baldes,doesnt matter.
If you wanted to send me a small chunk of material, I can bore it to size & cut the splines in it for you. Then you could weld or attach whatever you wanted to make it into any wrench?
Thanks, Tim Bostic
Hoss Marine Props
hossprops.com
Thanks, Tim Bostic
Hoss Marine Props
hossprops.com
Thanks tim, can you send me your email so i can get your address. it just needs to be a small chunk of metal,doesnt have to be stainless, so i can weld on a handle. i will send you some.
Offshoreonly Advertiser
I have #6 hubs as well if you don't want to machine or broach splines into raw metal.
Also curious what you need the splined part for. Rebuilding #6's?
Brett
Brett
[email protected]
[email protected]
Sounds good.
Are you taken care of?
Brett
Brett
[email protected]
[email protected]
Did you get fixed up or do you still need some help?
Thanks,
Tim Bostic
hossprops.com
