Any suggestions ? >
Any suggestions ?
Any suggestions ?
Old 06-16-2012 | 10:46 AM
Default Any suggestions ?
Here is my info./.Thinking about 33 herings 5 blade? Looking for more top end
Hering 6 blade 15.5
4,000 RPM to plane
3000 RPM 57 mph
3500 RPM 68 mph
5200 RPM 93.4
Maximus 5 blade 15.5/8
( conditions may have been better w cooler water and a tiny bit more choppy)
3,000 RPM to plane
3000 RPM 59 MPH
3500 RPM 70 MPH
5300 RPM 94.8 MPH
The six blade felt really nice as far as the boat getting set. boat felt nice ( not so glued in in the rear as the maximus)
mcprodesign is offline
Old 06-16-2012 | 10:50 AM
The top of the 1 1/4" propshaft is even w the bottom of the boat. 38 side by side fountain lightning w the smaller twin step hull
Old 06-18-2012 | 07:28 PM
bbladesprops's Avatar
Offshoreonly Advertiser
Smile
I believe we spoke this AM.
The Hering 5 blade should provide very good top end.
A Labbed Maximus could provide the best all around performance as well as better top speed.
Brett
[email protected]
bbladesprops is offline
Old 06-19-2012 | 11:12 AM
Brett
Looking to sell the 6 blade but they will be spares for now. Then I will get a set from you labbed or find a set of used 5 blade herings.. Thanks for your help.. The only props that have worked well on both of my last 2 fountains were props i got from you
Old 06-26-2012 | 01:38 PM
Brett, I spoke with you today and I must say that you have helped me out so much w my decisions in props ! You are a great guy to have around Thanks again
Chad
Old 07-03-2012 | 12:24 AM
Fwiw I found a deal on some 32 hering 5 bl. I think I need to be higher to run the 6 bl and it's already too hard to plane w my set up.
Also we can see what the real top end dif is between stock Hering and Maximus. I'm excited !
Old 01-23-2013 | 09:00 PM
I ran 98.0 @ 5500 yesterday with 32p 15.5 20 deg. Herings. Wow. I think I fouund the best thing out there. I am really happy with the props. Thanks Jeff
Old 01-24-2013 | 10:55 AM
Smile
Hey wait a minute. What about us? LOL
The stock Max props have .4% better slip number than the Herings. Labbing the Maximus props could and should be the better choice!
Glad I could help though................
Brett
[email protected]
Old 01-24-2013 | 06:12 PM
Hering 6 blade 15.5
4,000 RPM to plane
3000 RPM 47 mph
3500 RPM 58 mph
5200 RPM 93.4
3,000 RPM to plane
3000 RPM 50 MPH
3500 RPM 60 MPH
5300 RPM 94.8 MPH
All the cruise numbers were of by 10 mph. I fixed it.
Old 01-24-2013 | 06:15 PM
Brett
Brett you always help and I thank you. I will go no where else for Mercury props. Just that Jeff took care of me too. Thanks again for your continued support. Chad
