Prop washers for Hydromotive >
Old 07-13-2012 | 08:27 AM
Default Prop washers for Hydromotive
Is the only difference on Hydromotive Vs. Mercruiser Torq thrust the Castle washers?
Basically, if I buy a new set of castle washers can I leave the thrust washer and everything else alone going from a Bravo 1 prop to a Hydromotive?
VetteLT193 is offline
Old 07-17-2012 | 08:21 AM
It's been awhile since I had a Hydro on but if I remember correctly the thrust washers are identical.
ThisIsLivin is offline
Old 07-17-2012 | 08:41 AM
When I change out the Hydro's to Bravo's and vice/ vesa I used all the same hardware....and now you have me thinking as well.
verbi69 is offline
Old 07-17-2012 | 09:40 AM
97FASTech's Avatar
Veteran: Army
Just swapped mine, Bravo 1 to Hydro QIV, used same hardware.
97FASTech is offline
Old 07-17-2012 | 10:32 AM
bbladesprops's Avatar
Offshoreonly Advertiser
Smile
Square bore Hydros use all the same stuff.
Brett
[email protected]
bbladesprops is offline
