best prop 22 donzi >
best prop 22 donzi
best prop 22 donzi
Old 07-24-2012 | 11:13 PM
Default best prop 22 donzi
running 3 blade but want more stern lift at lower speeds
cig20 is offline
Old 07-25-2012 | 08:15 AM
Bravo one or rev 4 would do it.
GTOFFSHORE is offline
Old 07-25-2012 | 02:14 PM
What engine/drive combo on your 22?
My brother's 22 with a OMC King Cobra 454 runs a 22P x 14-1/2 OMC Raker (cupped 3 blade with a vent on the hub). Gets 5500 RPM.
techman is offline
Old 07-25-2012 | 03:30 PM
What combo?
I'm running a 496 HO.
I get the better top speed (77-78 mph) with a 27 Mirage Plus tapping on the limiters door at around 5200 rpm.
I also run a 28 Bravo I (carries the weight better when loaded with people), it tops out at (73-74 mph) at around 4800-5000 rpm.
The 27 Mirage Plus (3 blade) seems to give more bow lift and runs real loose while the 28 Bravo I (4 blade) runs more stable.
Hope this helps.
JustMercMe is offline
Old 07-25-2012 | 03:41 PM
A labbed B1 sounds like it might hit the sweet spot you are looking for.
techman is offline
Old 07-25-2012 | 06:36 PM
bbladesprops's Avatar
Offshoreonly Advertiser
Smile
Labbd B1 after stock base line testing would be my best option.
Brett
[email protected]
bbladesprops is offline
Old 07-26-2012 | 08:56 AM
trs 454 420hp
where to start what pitch
cig20 is offline
Old 07-26-2012 | 09:48 AM
a prop that works REALLY well on older 22's is the Hydromotive QIV.
My brother tried the Bravo 1 and hated it. He liked the hydro a lot... swore by his old 3 blade cleaver but could never find one big enough for his power after he upgraded.
VetteLT193 is offline
