need more rpm's
need more rpm's
running a 272 baja with a 572 at 32 degree timing. with xr and sporty lower pulling 4700rpms at 70-71 mph no chop. with a 28 bravo 4 blade, it comes on plane with real ease even with 3 people. mid range to top speed it pulls hard. My motors built to run 5500 rpm. any ideas what prop to try next?
update on light chop: ran a 30 bravo 66mph at 4400, ran 28 bravo at 48-4900 at 73mph.
comes out of the hole with both at major ease and from 3000 to max rpm it pulls hard
I built the 540 in my own 272 to run N/A and blown, N/A it made 650 gross hp with no accesories at 5600 or so, with a nose cone and std length drive it ran 75-76 with box stock 26 merc factory labbed at about 5400-5500 in PERFECT conditions so even though your motor is slightly bigger I think a 26 labbed might be what you need based on your CURRENT info. I remember your motor was supposed to be 728 hp and I figured you would be turnning a 28 labbed, sounds like maybe your not quite there hp wise when actually installed and running in your boat. When its hot or if its loaded too much my 272 is closer to 73/74 and is around 5300 or so as if a 26 labbed is slightly big , buy a 26 labbed 4 blade and have it tweaked. I have had great results with greg hittner/cutting edge props , waiting to try my 26 labbed again that he straightened out after I sent it somewhere else a few years ago only to see boat run slower even in the best of conditions , will be testing it N/A in fall again or possibly sooner if I shred my procharger between now and then! Smitty
Thanks Smitty i was waiting for you to chime in.
Im debating if i call greg or brett for a labbed prop from one of them they both sound like there good at what they do or just try find a used 26 off an OSO and try it out first to get a closer idea.
Are 3 blades on these hulls a waste of time?
Im debating if i call greg or brad for a labbed prop from one of them they both sound like there good at what they do or just try find a used 26 off an OSO and try it out first to get a closer idea.
I have not travelled south yet as it is quite a distance im about 750 miles to the twin cities in MN.
My boat actually came from bay city michigan 4-5 yrs ago.
this is what my motor ended up being:
572 ZZ block with callies 4.375 crank, manly rods, bore is 4.565 coated flat top pistons that make it 10.1, coated bearings, fusion coated Brodix BB3 extra cnc 365 heads, dart intake, 1050 dominater, ati balancer, msd box and distributor. teage 14 quart pan and big teage cooler with a 130 oil t-stat, gil exhaust with long tails, roller cam is duration@ 50 with 245 Intake 634 lift. exhaust is 253 with 642 lift, with 110 lobe seperation. timing is set at 32
Those are some sizable heads for those cubes. I went from Merlin 345's down to AFR 335's on my current 580 build. What does your torque and hp curve look like? I peak torque at 4900 and peak hp at 5900. I am aiming to prop at 5700 due to the broad curves on both hp and torque. Looking at the dyno really helps explain some things when propping but looking at your previous results I would go with CEP 26 or send a bravo 4 26 in to brett at bblades and have him lab it. Should get you close to 5400 +/-. Hopefully the extra R's helps the port velocity in those gnormous heads. Those have to be a torque burden in the midrange but if you get over it may make some good power up top. Also, I am running 35*. We dynoed at 36* with the best result but left a little cushion for gas, temp, ect..
