Bravo 1 prop on Bravo 2? >
Old 08-16-2012 | 03:28 PM
Default Bravo 1 prop on Bravo 2?
Hi,
i would like to know if i can use a Bravo 1 (48 831912) prop on my Bravo 2 drive. What is the difference between the Bravo 1 & 2 drives?
The prop i`m using now have a "A40" at the end (4818616 A40) What does this stand for?
Can i use a prop with a different "A" number e.g. A50?
westct is offline
Old 08-16-2012 | 06:09 PM
bbladesprops's Avatar
Offshoreonly Advertiser
Smile
Unfortunately the 2 are not interchangable due to the hubs.
Brett
[email protected]
bbladesprops is offline
Old 08-17-2012 | 10:38 AM
Too Stroked's Avatar
The Bravo 2 drive was designed for big cruisers to give them more "bite" and swung a much larger diameter prop for that reason. If you look at a Bravo 2 side by side with a Bravo 1, you'll swear that the 2 is spinning a fan blade, not a prop.
Too Stroked is offline
Old 08-18-2012 | 04:20 PM
So the main difference betwen bravo 1 & 2 is the size of prop that will physically fit the drive and the shaft/spline?
is there a hub kit that will make it fit the shaft?
westct is offline
