To polish or not to polish?
Where did you come up with that? I think you might be off a little/bunch.
2 tonchevy, As far as Merc putting Hi Polish on Chopper 2's.................there is a slightly long story I will shorten. You bought stock Chopper 2's. If you bought Labbed Chopper 2's, they would have been Satin finished. Scott (Merc Racing) decided to go Hi Polish on the stock OB cleavers and choppers because of the bling affect and production processes that I will not divulge.
Bostic, I said it is up to the customer how they want the finish. I didn't say there is no difference in performance. I believe/know there is a difference in performance. On average 1 mph or less can be seen but we have simply put our satin finish on out of the box props and have seen gains close to 2mph. Most of those results were on single engine OB boats but twin stern drives get results too.
Again, I've had this dicussion turned into a argument before. It's simply not worth the waste of time trying to talk somebody into it. That's why we let the customer decide. If they want our advice, it will always be satin race finish. Believe me, there is a trick to putting that finish on too. You need the correct equipment and a ton practice.
Brett
Brett
[email protected]
[email protected]
Brett
I'm not trying to start an argument here..... just stating what our testing showed yrs. ago.
If someone (Mercury or you for that matter) tested it & said it was 1 mph faster, then that's good enough for me?
I'm not saying that the 1 or 2 mph gain is incorrect ..... all I stated was our results.... no change in RPM & no change in MPH..... Again, sorry if our results didn't match yours?
I'm sure we didn't know how to put a "special" satin finish on the prop in the first place, since everybody knows how to put a high polish on one.
Again, Sorry for the Mis-Understanding,
Tim Bostic
Hoss Marine Props
Tim,
No harm done.
I am just stating our findings at BBLADES and Mercury Racing from much testing. You need to test these things more than once.
Thanks Brett
No harm done.
Thanks Brett
[email protected]
[email protected]
Our actual test was done to determine whether polishing a prop increased performance & we determined it didn't help much at all, but decided that the "bling" factor was necessary for the customer, so we worked on making a beautiful prop along with the added performance of a custom prop.
(Like I said, my own props are satin finish - hehe!!!!)
Thanks,
Tim Bostic
Hoss Marine Props
2tonchevy,
Testing the stock propeller first is the best way to determine what kind of lab finish would be needed.
Thanks Brett
Thanks Brett
[email protected]
[email protected]
Think of a drop of water on a table. Touch the water with the smooth rounded bottom of a spoon and lift slowly. Notice the elasticity of the water adhering to the spoon. Now sandpaper the spoon bottom and try it again. The water will not adhere to the spoon. This is a slightly gross exaggeration of the affect but it does represent what is going on here. Very slight (very slight) grind marks do the same thing on propeller blades.
Brett
Brett
Cohesion: Water is attracted to water
Adhesion: Water is attracted to other substances
