Prop Hub Milling >
Prop Hub Milling
Prop Hub Milling
Old 09-19-2012 | 04:35 PM
Plum_Crazy's Avatar
Default Prop Hub Milling
I have a set of Herings for a 1" Bravo shaft. Hering wants $1000 each to change the hubs to 1-1/4". Can these be milled to the new size? If yes, who can do it?
Plum_Crazy is offline
Old 09-19-2012 | 06:04 PM
HiPerf2000's Avatar
hydromotive changed my solid hub hydro's from 1" to 1.25". think it was under 200 per prop. you may want to call them to see if they would do it ?
HiPerf2000 is offline
Old 09-19-2012 | 06:27 PM
Plum_Crazy's Avatar
Thanks!
Old 09-20-2012 | 02:30 PM
bbladesprops's Avatar
Offshoreonly Advertiser
Smile
We do this all the time too. Changing the 1" insert to the 1.25" insert is different than changing a Hering. The Hering hubs/splines are machined and broached into the casting itself. This requires a much more indepth process to change to 1.25" since the old splines will need to be machined out
Herin will be changing their castings in 2013.
Brett
[email protected]
bbladesprops is offline
Old 09-20-2012 | 09:08 PM
Plum_Crazy's Avatar
So, only Hering can do it?
