Question on non-go-fast boat props >
Old 10-31-2012 | 12:32 PM
waybomb's Avatar
Active Streak: 30 Days
Active Streak: 60 Days
Active Streak: 90 Days
Default Question on non-go-fast boat props
My other boat has 22 x 22 4blade nibral Michigan Wheel props, 1 3/8" shaft.
I have been looking for a cheap set of used get-home props, but they all seem to be 1.5 or larger.
Does somebody make bushing to reduce a larger-bore prop? Where can I get a couple?
waybomb is offline
Old 10-31-2012 | 05:48 PM
1 3/8" is a weird size ? usually jumps from 1 1/4-1 1/5 ?? but I have never seen a bushing to do that..would not use one if they made it.....don't think you would ever get to seat right..??
ezstriper is offline
Old 10-31-2012 | 06:20 PM
waybomb's Avatar
Yup, it is most definitely 1 3/8" shaft, with a taper at the prop mating surface. Measured multiple times. I then went to a Carver related website and they verified it for me, because like you it sure seemed like an odd size.
waybomb is offline
Old 11-01-2012 | 01:38 AM
There are bushings made to reduce bore size. Anchor Bushings is the most well known manufacturer.
http://www.propshopinc.com/Anchor-Bushing-v4/
Philm is offline
Old 11-01-2012 | 12:38 PM
waybomb's Avatar
Hey PhilM- THANK YOU! Only 27 bucks each!
I just bought a nibral michigan 22 x 22 x 1.5 on ebay for a hundred bucks. So I'll have 127 into a spare prop that I could use all the time if needed. What a deal Now looking for the RH side.
waybomb is offline
