Baja 277 Islander Prop Help >
Old 11-13-2012 | 07:45 PM
Default Baja 277 Islander Prop Help
Looking to buy a 2008 Baja 277 Islander, 496 HO with a bravo X drive. It currently has a 4 blade stainless 21 pitch prop on it. Can anyone tell me if this was the stock prop utilized by Baja back then on this boat?
Bad Bird is offline
Old 11-14-2012 | 12:14 PM
bbladesprops's Avatar
Offshoreonly Advertiser
Smile
There really hasn't been a "stock" propeller set up on many boats for years now.
Since there are more propeller options and power options, the dealers typically put what they feel is best or more often what he has available.
There is of course, a kind of go to propeller for a boat such as yours. This would be a Mirage Plus. Here at BBLADES we have been turning alot of Islander owners into 4 blade fans because of the water sports advantages and the load carrying advantages. Our go to propeller in that situation is currently the Revolution 4.
If you have a 21 Rev 4 and the rpm level is between 4700 and 5100 you are doing fine. There can always be some tweaking to be added if desired.
Brett
[email protected]
bbladesprops is offline
Old 11-18-2012 | 08:19 AM
Thanks Bret, As always you have good insight regarding prop applications. I appreciate your feed back!
Bad Bird is offline
Old 11-21-2012 | 02:05 PM
Smile
Your very welcome.
Let us know if you ever want to test some other propellers.
Happy Thanksgiving.
Brett
[email protected]
