Prop size in formula where do I start >
Old 05-08-2013 | 10:05 AM
Default Prop size in formula where do I start
Need help determining what prop I need if I were to put a bravo one with 1.65 gears on a 88 formula 242 with a stock 454 ?? Wot rpm is like 4600 I believe
Matjluk is offline
Old 05-08-2013 | 11:52 PM
I'd start with a Bravo 1 24" four blade. A Revolution in the same pitch might work as well.
Trash is offline
Old 05-09-2013 | 12:10 AM
I was going to suggest a lab finished 25 4 blade Bravo to start. I would contact BBlades, they have props you can "rent" to try out and will also help you determine what prop is best for you, real nice guys, I believe the owner worked for Merc Racing for years, really knows his stuff.
Gun Slinger is offline
