21P or 23P Mirage Plus for 26 Scarab >
Old 05-19-2013 | 11:49 AM
badmonkey's Avatar
Default 21P or 23P Mirage Plus for 26 Scarab
Hoping someone can give me the proper insight...want to purchase a new 21p or 23p Mirage Plus for my 26' Scarab. Currently running a 23p Mirage (standard). What will give me the best overall performance. Thanks in advance for the help.
badmonkey is offline
Old 05-19-2013 | 12:28 PM
What engine? What rpm and speed (GPS) are you running now? My recommendation is to use the prop slip calculator--10-12% slip is the goal and about as good as you are going to do.
Prop Slip Calculator
Powerquest_Baby!! is offline
Old 05-20-2013 | 06:13 AM
badmonkey's Avatar
502MPI running at 62 MPH @ 4900 rpm
Old 05-20-2013 | 06:12 PM
bbladesprops's Avatar
Offshoreonly Advertiser
Smile
At 12.85%, I'd Lab your 23 M+.
I believe you talked to Brad and He explained how the 21 will most likely put you in the rev limiter. You will also lose cruise speed with the 21.
Let us know if there is anything else we can help with.
Brett
[email protected]
bbladesprops is offline
Old 09-02-2013 | 12:54 PM
I have the same boat with same engine , mine revs 4300 with a 25 mirage top speed 60
Bulitz is offline
Old 09-26-2013 | 01:59 PM
bulitz- your rpm seems low
KMONEY306 is offline
Old 10-02-2013 | 06:23 AM
Thebossbultsma's Avatar
I have a 24 foot predator with a 496 built to 450-500 hp. Bravo 1 1.5 ratio and my 23p just spun out all the time I went to a 24 bravo 1 4 blade and love it to death the boat gets out of the water so fast and it will run 70 plus at 5000rpms.
Thebossbultsma is offline
