Bravo 3 props >
Bravo 3 props
Bravo 3 props
Old 06-18-2013 | 09:41 AM
Fenderjack's Avatar
Pirate of the Chesapeake
Default Bravo 3 props
Do late model swept back bravo 3's take a different prop set than the early square back drives.Put a set on my neighbors swept back and the front prop is riding on the alum around the prop shaft on the housing.Like the ID on the prop is to small to go over the alum.housing. JOHN SR
Fenderjack is offline
Old 06-18-2013 | 10:26 AM
Knot 4 Me's Avatar
No, they take the same props. Sounds like you left the thrust washer off. The prop hub rides inside the drive housing, not outside.
Knot 4 Me is offline
