what size props?
I have a 85 fountain 10meter.trs drives w/velvet drive trans.the motors are 454,s bored and stocked to 496ci.nothing fancy,i am guessing the h/p is around 450-500.what size props do you guys think I should be running?
Due to the vintage, I would use the Bravo propellers. The trailing edge configuration will give you the better boat attitude. Pitch will be determine by the actual HP and rpm you desire to turn the props.
We have these props for testing without needing to buy anything.
Let me know if you would like to try our test program. Otherwise we can determine the correct pitch with some other basic knowledge about your set up. Call me anytime.
Brett
Brett
[email protected]
[email protected]
