Mirage vs mirage plus? >
Old 09-17-2013 | 08:24 PM
Default Mirage vs mirage plus?
Hey guys I have a Formula 303 Sr1 with twin 502 EFI's and Bravo 1:36 drives, currently twisting 23 Mirages, Wondering what you hink a set of plus's will do, same size, or should I jump to 25's, currently if I go for gold it spins 51/5200 rpm's I think I want to be below 5000 r's, best ever is 77 on Gps, pretty much always runs 74,
thanks
88242LS is offline
Old 09-17-2013 | 08:36 PM
5200 goingb77 gives you under %8 slip..... That's darn good. You can get sets of 25+ darn cheap if ya keep an eye out.... I would give it a shot if your not having a problem hitting the limiter
mptrimshop is offline
Old 09-18-2013 | 12:04 PM
bbladesprops's Avatar
Offshoreonly Advertiser
Testing the 25 M+'s makes sense. You may need to Lab Finish them to get where you need to be.
Brett
[email protected]
bbladesprops is offline
Old 09-18-2013 | 03:42 PM
Hello,
The Mirage Plus as the name implies, has more cupping than the original Mirage and will generally turn 200-300 less rpm in the same pitch. If you go to the 23" Mirage Plus's, your rpm will drop 200-300 anyway. The other option is to find a good used set of 25 Mirage's, not Plus's.
Thom
hec2buck is offline
Old 09-18-2013 | 04:34 PM
thanks guys I may have located a set to borrow, and test out
88242LS is offline
Old 09-19-2013 | 02:57 AM
Let us know how it works out
