Under propped??? >
Under propped???
Under propped???
Old 11-12-2013 | 04:15 PM
Default Under propped???
So I finally got on her Sunday and took the 88' Formula SR1 311 up to 5k rpms. I had throttle left and barely any trim. My gps said that I was going 53mph which I believe is off because I was running door to door with another boat and there gps was reading 61mph. I have mirage 23s on there now and figure I need to go up seeing I have throttle left. What should be a good prop to move up to. I had the 25+ on there and that was to much so should I go with a 25, 23+, or a bravo 24.
s022mag is offline
Old 11-12-2013 | 06:02 PM
Did you push it past 5k to see if it hit the limiter?? Also what engines/wot range. Summer heat will knock off a cpl rpms so you might be propped right??
nailit is offline
Old 11-13-2013 | 07:01 AM
454 420hp each. I had plenty of throttle and trim so I don't think it was the cold air or water that allowed it to turn that easy. Did not push it pass 5k rpm either.
s022mag is offline
Old 11-13-2013 | 07:30 AM
Merc 420's are pretty stout motors, bury the throttles and trim er out. If it still has the original ignitions I don't think there is a rev limiter but I wouldn't worry about the rpm unless it starts getting up around 5400. The 420's have a much better valve trane setup than a 454 mag. You need to see where you are really at before you change anything. That boat should run 65+ trimmed out.
dandercam1 is online now
