-   Prop Talk (https://www.offshoreonly.com/forums/prop-talk-165/)
-   -   Prop size for a Sonic 386 w/502 Stock MPI's? (https://www.offshoreonly.com/forums/prop-talk/310260-prop-size-sonic-386-w-502-stock-mpis.html)
shotjock 03-29-2014 11:48 AM
Hello. I am running 26p's 4 blade and only getting about 64 mph @ 4400 rpm max. The manual says "mid 70's" with stock power. Any ideas on what props I should be running? Thank you!
Avs38 03-29-2014 01:18 PM
RPM seems low. 28 probably the right pitch IMO
RT930turbo 03-30-2014 09:04 PM
What power? And if you're only spinning 4400 with 26, 28 will be even worse.
BUP 03-30-2014 10:15 PM
Stock 502 MPI should be 415 hp. Totally agree you need to come down on the pitch #'s, Also I would have to ask how well are your motors running ?
kjberman 03-31-2014 10:14 PM
Mid 70's? unfortunately that is not possible with your power....
358's with 500's run mid 70's. You probably have a 66-67mph boat.....maybe try 24p props.....maybe 23p.
