Volvo DPX drive/ E series prop help >
Old 05-20-2014 | 10:41 AM
Default Volvo DPX drive/ E series prop help
Hey guys,
Pretty new to the forum, I have a 2002 Conquest Top Cat that had an Innovation DPX600 package in it. Swapped in a Procharged BBC estimated around 800hp and kept the Volvo DPX duo prop drive. While it runs good, I'm WOT @ 5800rpm @ 72-74mph with the E2 props. E3's didn't really change it either. Was wondering if anyone thinks the E4's will make a difference before I spend $1500 on a new set or if I should look into gearing first. Can't find many people with DPX experience so any insight/advice would be appreciated. Thanks!
Crl132 is offline
Old 05-20-2014 | 02:56 PM
bbladesprops's Avatar
Offshoreonly Advertiser
We have done some repairs and truing to these propeller. There are only 3 sizes available to my knowledge.
It is strange the E3's didn't change something. Could you possibly be on the rev limiter?
Brett
[email protected]
bbladesprops is offline
Old 05-21-2014 | 12:45 PM
Those numbers seem right on using a prop slip calculator and a 1.78 gear ratio your at 10% slip. I was told by Bronson/Hill these are the average combined pitch of the following propellers:
E2........26.8 pitch
E3........28.4 pitch
E4........29.5 pitch
Good luck a gear change to 1.59 would be ideal a gear set runs around 3000 for parts that's the only bad thing about the DPX drives parts are expensive..
Eagle 25 is offline
Old 05-21-2014 | 01:06 PM
Dang, yeah I figured the gear set wasn't cheap. Thanks for the info Eagle!
Crl132 is offline
Old 05-21-2014 | 04:59 PM
make sure you have the props timed rite or all your going to do is get high slip numbers and go no where..i never line up the props..i mount the front dlade so the lower 2 blades are at 5 and 7 o'clock (with in reason ) and the outter blade with one at 6 o'clock..this way worked the best..
FIXX is offline
Old 09-11-2015 | 06:23 AM
am looking to get smaller props. I have a 340 Powerquest vyper boat with Volvo dpx drives with e4 props. I repowered the boat from 525s to stock carb 502s. The e4 props r wayyy too big anyone has any information if I can go to a f series prop r do I have to stay with an e series because an e2 is the smallest they have. Any information would be helpful
Thanks a lot
C Roussel
slippy0217 is offline
Old 01-04-2016 | 11:36 AM
I had a 2000 388 Hustler with DPX 600's and DPX drives.
Boat ran 89mph best top speed.
I've got 2 dpx props sitting around, lab finished like new.
They are the larger of the 2 props on the drives.
I'll have to check the size.
Teddy G is offline
Old 01-04-2016 | 11:53 AM
[ATTACH=CONFIG]549340[/ATTACH][ATTACH=CONFIG]549341[/ATTACH][ATTACH=CONFIG]549342[/ATTACH][ATTACH=CONFIG]549343[/ATTACH]
E4-Fronts...
Attached Thumbnails Volvo DPX drive/ E series prop help-pa220039.jpg   Volvo DPX drive/ E series prop help-pa220040.jpg   Volvo DPX drive/ E series prop help-pa220036.jpg
Volvo DPX drive/ E series prop help-pa220037.jpg
Teddy G is offline
Old 01-05-2016 | 05:03 AM
scarabman's Avatar
Were they labbed by Bronson Hill? Thats who had done mine many yrs ago. What are you looking to get out of them? I know several guys still running DPX drives, myself included.
scarabman is offline
Old 01-05-2016 | 11:00 PM
BUP
there is only 3 E series props and If I recall as well, post # 3 has the correct info for avg combined pitch per E series
BUP is offline
