Checkmate Enforcer Prop Choice - Need roughly 500-600 rpm increase >
Old 05-29-2014 | 11:13 AM
Default Checkmate Enforcer Prop Choice - Need roughly 500-600 rpm increase
I'm looking for some advice on which prop to go with on my 24' Checkmate Enforcer. It has the 350 Mag engine with Alpha 1 outdrive (1.5:1 gear ratio I believe).
I purchased the boat towards the end of last year and noticed right away it had to steep of a pitch prop. WOT and trimmed out it would peak around 3900 RPMs plus or minus a few. It had a generic 23p stainless prop on it (not sure of the brand) . After doing some research I picked up a 21p Mirage Plus hoping to raise the RPM's some which it did, but not as much as I was hoping for but the speed definitely picked up. I had the boat out last weekend currently and as it sits with the 21p Mirage+ it is running 4100(ish) RPM's according the the factory tach @ 49mph (GPS).
I would really like to get the RPM's closer to the 4500-4800 range where they should be. Any particular prop I should look at? I have been doing a lot of research on the different model props and the more I read the more I start double guessing which model I should get. I've looked at the standard mirage, laser II and of coarse the Mirage+.
I was thinking of going with a 19p mirage (non plus model) hoping that it would get my RPM's up where they need to be. Any ideas?
Thanks!
JimNut is offline
Old 06-01-2014 | 06:29 PM
bbladesprops's Avatar
Offshoreonly Advertiser
JimNut,
It looks like the current prop is hooked up well. You just need to get more rpm to save the engine. We have a test propeller option for you.
Call us if you desire and we can get some test propellers for you.
Brett
[email protected]
bbladesprops is offline
Old 06-02-2014 | 09:33 AM
see if you can find a 19p mirage and mirage + to test before purchasing one.
sabo is offline
