-   Prop Talk (https://www.offshoreonly.com/forums/prop-talk-165/)
-   -   opinions on this prop advise? (https://www.offshoreonly.com/forums/prop-talk/314922-opinions-prop-advise.html)
tnc110 07-08-2014 09:06 PM
Trying to figure out a good starting point for prop selection. I bought a 625 hp 540 to put in a Donzi 25zx. Right now boat runs 60-62 with a 454mag and either a 21p mirage plus or a 21p rev4 at 4900rpm. Owner of the 540 states that he was running 90 mph at 5600 rpm with a 28p bravo1 in a 253 checkmate.
Prop guy says add 1" pitch for every 100hp. He also states that for every 200rpm increase I should figure on 1" less pitch...so basically I should be pretty close with staying at 21p. Sound right?
akaboatman 07-08-2014 10:34 PM
No
ealesh33 07-08-2014 10:43 PM
I am not sure I believe what the guy said he got in his checkmate, I don't at all actually. For one a. 6.75% slip is completely unrealistic, but 650hp in a 24 outlaw (which is very similar type hull) will spin a 26p bravo 1 to about 5600 at about 78-80mph. I would say a 26p is probably a good starting point depending on what rpm the motor makes peak power at
thirdchildhood 07-09-2014 06:28 AM
Bravo 1 props are different. I run a 30p Bravo 1 labbed by Brett. My boat could not pull a 30p of most other prop types.
GeeterB 07-09-2014 06:31 AM
I own a 253 and you will not go 90mph with 625hp 540. not even close.
sabo 07-09-2014 06:35 AM
The checkmate is going to run around 80, not 90 with 625hp.
is your drive ratio 1.36? cause with the numbers you gave 1.36 ratio would be around 14% slip and 1.5 would be only 5% slip.
you can start with the 21 and get a baseline, it will probably be too small, then go from there, depending on top speed you shouldn't need more than a 24p with a 1.36 drive.
tnc110 07-09-2014 07:57 AM
1.5 drive
ealesh33 07-09-2014 09:21 AM
Bravo 1 props aren't true to stamped pitch, they are under pitch. 24 is 23.3, 26 is 25.3, etc...100hp took me from spinning a 23p mirage at 4800-4900 to spinning a 26p bravo 1 to 4800-4950. 625hp I think the 26p bravo 1 is a good starting point to get a baseline and very well may be the prop you end up needing
tpabayflyer 07-09-2014 11:46 AM
My 26ZX spins a Bravo 1 26P to 4900rpm at 69mph.... This was into the wind and against the current so I think it has a few more mph in ideal conditions....Motor is a new 502 with ported aluminum heads and 10-1 C/R and was not dyno'd but I would say around 600 ft/lbs torque is pretty close..... cruise is awesome @50mph at 3,500rpm so I think this is the perfect prop...... Your motor with a little more power and a little lighter hull should get you up to the mid 70's I bet....... I also think the 26P will work the best for you... TBF
sabo 07-09-2014 01:37 PM
tnc110 something isn't adding up, with the numbers you gave that's only 5% slip, your going to have at least 10% slip. That being said, either speed, rpms, pitch or gear ratio is different than what is stated.
run the 21 or borrow a 24 or 26 and get some baseline numbers and go from there.
