Scarab 300 help >
Scarab 300 help
Scarab 300 help
Old 07-24-2014 | 08:34 PM
cigboat1's Avatar
Might be easier to find the cleavers or the mirages floating around also a lot cheaper ----I have a pair of 23 cleavers you can try on the boat but I do not want to sell them. have to dig them out from one of my old boats.... Call me if you want to try them out ------440-967-6683
Jim
The cleavers will give you more top end but they are tricky to come on plane some times.
cigboat1 is offline
Old 07-24-2014 | 08:48 PM
SB
Those motors are fine, but you must remember several things:
1) Your peak hp will be somewhere around 5500-5800rpm. The cam specs you gave are the Comp Magnum 280H Flat Tappet Hydraulics. Those where used millions of times back in the 80's + 90's. Not in boats much. Not that that means anything, but more that I and millions of other know where they perform up to.
I'd prop for 5400-5500 rpm first. And maybe try a little higher from there.
2) They are 350's. You have a heavy boat that sits/rides in the water a lot. Don't overload them, let them get to the rpm they make most power. They should start to sing nice from 4800rpm and up.
SB is offline
Old 07-25-2014 | 09:30 AM
Jim
Thank you very much for your generosity, I will try to find a set I can buy first then go from there.
Baldie is offline
Old 07-25-2014 | 09:31 AM
Yes, I understand most of that, as I can get the same speed out of the props that are on the boat at 4500rpm as I can with a true set of 25P mirages at 3200rpm, but it just seems that there is tons of stearn in the water right now - more than what there should be anyways.
Baldie is offline
