Help me pick a prop! >
Old 08-03-2014 | 10:32 PM
Originally Posted by ealesh33
I personally would just wait till I got the exhaust on and then prop it to where I wanted it instead of trying to guess how much you will get from the upgraded exhaust. There are aeveral factors on how much the exhaust will gain you over stock manifolds. How big your cam is, usually stock exhaust is no good with a cam unless it's pretty mild, reversion is the issue. Heads, and your induction play a roll as well. But with CMI e tops and generally speaking probably 200rpms over stock manifolds.
Thanks for the input. I had actually already ordered a B1 24P before I decided to order the headers... The mod bug bit me and as we know it doesn't normally bite at the best time. Haha.
I put the new prop on yesterday and it's a night and day difference from the stock previous 3 blade 26p. It planes in half the time and feels much faster mid range and even to top speed... I didnt loost much top end. Maybe 1mph and it gained about 300 rpm. It's like a totally new boat! Love it even more now! Hopefully the headers help out even more.
RAC3ME is offline
Old 08-04-2014 | 04:15 PM
I'll be watching your threads closely, I feel that I'll need a new prop after I get my engine back.
Cole2534 is offline
Old 08-11-2014 | 09:23 AM
I have a 28p Bravo1 on my boat 24cs with 600hp. Haven't got to really run it out yet do to crappy water every time we have taken it out! I'm curios to see how it does.
Patchman460 is offline
Old 08-11-2014 | 11:54 AM
I bet that 28p is spot on for 600hp. Let us know how it does when you get it on the water...
RAC3ME is offline
Old 08-11-2014 | 12:27 PM
We are going to Lake Somerville August 22-23 for Rocking the Cove. So hopefully I can find some smooth water to run it out a little.
Old 09-05-2014 | 05:25 PM
Well got a chance to run the boat some more, discovered a oil leak, and a leak on one of the trim tabs. So no all out passes, but did get to stretch it's legs a little. She ran up to 67 and had allot more to go. At around 2200 to 2500 it cavitates allot. Seems to go in and out. Talked to a good friend who has been around Fountains, and he said that the Bravo I have is probably the wrong prop. So I'll run what I have for now, and continue doing my homework on prop options. The biggest problem I have ran into was people not being real familiar with the 24CS.
Old 09-05-2014 | 08:16 PM
Tinkerer's Avatar
Dale - the short block that You bolted your heads and part on - did you buy one for a car?
You probably have too mild of a cam.
Tinkerer is offline
Old 10-22-2014 | 07:32 AM
Any updates here?
Cole2534 is offline
Old 10-22-2014 | 01:15 PM
Originally Posted by Cole2534
Any updates here?
Well I have been working bugs out of my combo. Got to run it a couple of weeks ago, have a oil leak to fix, then it's time for some serious runs. It turned 5 k with the 28p on it no problem. I still had some throttle left in it, but I was running out of water. So I'm close to having some useful info soon.
Old 10-23-2014 | 11:31 AM
I bought a 28 hydromotive Q IV to try. My test report says the 502 mag spun a 27 Q IV out, so hopefully my new 509 will wind out a 28.
Cole2534 is offline
